Thanks guys a ton...i'll check that part number. Just so you know i'm not crazy, here's the problem i'm trying to solve.
With a home theatre system, it appears that most systems have the front 3 channels at the same power (clean watts). So i've got the 2 pentas up front and the subs are big and very powerful. This leaves the AV7000 at only 45 watts up front. So, i'm wanting to bring this down to line level, run it into another very clean amp at about 120-150 RMS and then into a reference type center speaker.
Basically, i'm just trying to balance everything and give enough voice out of the center so i can hear the dialogue.
Thanks again, keith
