I was just recently given a 9300 and Beolab 8000 speakers and have not had much luck understanding how to properly
hook the speakers into the unit. I know it was working when it was disconnected  but do not know if all the wiring
made it in the move from one house to another . My question is do the Beolab 8000's need a power cord attached to them
when you open the panel on the bottoms the DIN plugs in and there is a power(or what looks to be a power connection) there under
the pop up. Is this a standard power cable or is it a cable that plugs into a transformer don't want to plug anything in until I know.
Oh BTW I did not get a manual which is why I am a bit in the dark. Any help appreciated.
