I have decided me for a couple of beolab's 8000 & my concern is which Beosound i should choose?
If i leave the specifikations aside & let the logic talk - Then the later must be better, or??
But, isnt the outside just a another packaging however with the same inside??
If someone know for a fact that there differences between the Beosound models, plz tell me!!
Kindly regards
Mathias
