Latest post 11-11-2008 2:59 PM by stotty1111. 2 replies.
Page 1 of 1 (3 items)
  • 11-11-2008 10:10 AM
    Beocenter 9300 radio - help!
    I have a lovely Beocenter 9300 which I bought a couple of years ago. Everything'sw perfect except the radio. When I tune it the display indicates that it has indeed found radio stations because it stops at them, however, there's not a sound to be heard, I've tried a couple of aerials on it - including the specific B&O model - but to no avail.... Any ideas folks?
    What's your favourite tune?
  • 11-11-2008 2:44 PM In reply to
    Re: Beocenter 9300 radio - help!
    My guess is that the radio is tuning ok as it is stoping at stations. Suspect the "mute" circuit. Will require service department investigation I'm afraid.
    Regards Graham
  • 11-11-2008 2:59 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    could try muting on / off several times might make contacts in the relay become active - do you get sound changing the speaker outlets over ie sp 1 to sp2 etc
    salut
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
