1st March February 2012
Latest post 01-06-2009 1:01 PM by JC. 16 replies.
01-05-2009 5:49 PM
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
Hello All the lcd display on my beo4 has been broken today and i wonder if that can be replaced and if anyone knows the sort of amount it will cost to get repaired at the dealer or someone else who can do it. Thanks
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
Yeah once you obtain the part you can do it yourself if your a clever fairy
Seanie_230
- Posts 962
thats good i shall order one today. so with regards to fitting is it a solder job or just pushing a cable into a connector and putting it all back together? any info on how to do this woudl really help Thanks
Seanie_230
- Posts 962
Dave:Yeah once you obtain the part you can do it yourself if your a clever fairy
dave you cheeky boi i will speak to you on MSN mr lol
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
No soldering required, the screen is held in place by double sided adhesive foam tape. It should also come with a new zebra rubber strip which you should avoid handling with bare fingers. Chris.
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
seanklemis:wicked thanks... i had it replaced at my dealers today as he can do it in half the time i can
How much did he charge?
Seanie_230
- Posts 962
hi there was just £25. Thanks all
Seanie_230
- Posts 962
this topic has promted me with two other questions 1) is it possible to take the insides of the beo4 out so io can clean the front esier as its a b**ch to do with cottom buds every now and then 2) can the cinema beo4 still be bought and if so how much are they?
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
seanklemis:1) is it possible to take the insides of the beo4 out so io can clean the front esier as its a b**ch to do with cottom buds every now and then
yes, but be careful when extracting and reinstalling the rubber keypad -potential tear. also, the plate is very "soft" -very easily bent, and don't be too agressive w/ the cleaning. it does work well though for getting any grime out close to the buttons.
burantek
- SE USA
- Posts 6,214
jandyt!!! i was thinking: you might need a hobby! oh! er, ah... perhaps you already have one! LOL
Seanie_230
- Posts 962
Jandyt:I do it often!
goodness me, ill send mne right over lol
JC
- Yorkshire / UK
- Posts 621
Just finished stipping down a cleaning 4 of my own, replaced a screen at the same time. It is quite therapuetic to be honest Cinema versions are rarer than hens teeth. If you find one expect tp pay around £250 to £300 2nd hand, unless you find someone who is unsure of his B&O. Jonnie
Page 1 of 1 (17 items)
