Latest post 11-12-2008 5:14 AM by lausvi. 3 replies.
Page 1 of 1 (4 items)
  • 11-11-2008 5:16 PM
    • dko7113
    • Top 500 Contributor
    • Joined on 09-04-2008
    • Copenhagen, Denmark
    • Posts 104
    • Gold Member
    MX 1500 can't remember...
    ...settings of sound and picture (ex contrast). Does it mean replacement of the back up battery? No problems with program presets. /Erik
    My Beo: BeoCom 6000, BeoCom 2500, BeoCom 1401, BeoLine, BeoVision LX6000, BeoVision LX2500, BeoVision MS6000, BeoVision MX4002, BeoVision MX1500, DVD1, BeoSound 3200, BeoSound 1, BeoLab 4000, BeoGram 4500, BeoPort, BeoPlayer, 3x Beo 4, 2x BeoLink 1000, V Terminal, Form 2, Light Control 2, BeoTime
  • 11-11-2008 6:05 PM In reply to
    Re: MX 1500 can't remember...
    Yes it needs an internal nicad replacing
  • 11-12-2008 2:10 AM In reply to
    • dko7113
    • Posts 104
    • Gold Member
    Thank you, sgresswell...
     Do you have the specifications of the back up battery?
    Is it easy to find?
    /Erik
  • 11-12-2008 5:14 AM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    At least in my Beovision MX3000 the battery is 2,4v NiCd, with soldering tags on both ends. My electronics dealer had one in list and I order but received an NiMH-type. When I asked they told me that EU will deny making cadmium-batteries and so the type in catalogue was replaced. Also I was told that in these type of application the NiMH type can be used to replace the NiCd.
     The battery looks like this (the actual one is a bit longer): http://www.wd-is.de/wdis/wenbilder/23004.jpg
    Bang & Olufsen - The art of controlling sound, picture and light
