Hello,
I can't find the AV function in the IR list because I need to have this in order to activate the DTV function but without switching the screen on.
Maybe there's another way to do this...
Yes, there is. Create a button that sends the SAT command in audio (RADIO) mode.
Stefan
Poor me, never win owt!
Sorry, maybe I didn`t make it really clear. You don`t have to press RADIO and SAT. If you have the Beo5 Config. tool you create a button that looks like this: 0:000: RADIO: V-SAT. You can name this button for example. AV-DTV. This is the button that will activate DTV (SAT) in AV mode. It´s a one-button-solution.
Good luck
OK Stefan, thanks!
This was the answer I was looking for
