Latest post 10-26-2008 8:43 AM by Dillen. 1 replies.
Page 1 of 1 (2 items)
  • 10-25-2008 7:42 AM
    BEOCORD 8004
    Hi - I've had problems with my Beocord and beleived the proplem was related to a known issue of worn belts, so changed them (Thanks Martin).
    But it seems i've not completly resolved the problems..hence this post.  The display is showing strange things and the tape deck engages but then stops straight away...Please help!
    While I replaced the belts I noticed there is a resistor (I think) that is missing... see attached.
    http://docs.google.com/View?docID=dhssz7f3_0fp7sxwdg&revision=_latest
    http://docs.google.com/Doc?id=dhssz7f3_4hnfcjv6r
    Whay do you suggest?
    Thanks, Jay
    Filed under:
  • 10-26-2008 8:43 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: BEOCORD 8004
    The trimmer has fallen apart, replace it - and and oterh trimmer of the same type - and readjust to factory specs.
    The garbled display is a different issue, not related to neither the motor/belts nor the trimmers. Check that all cables are on correctly and the connections between the display and sound control boards are good.
