TWG: I put the Beo 5 on its charger yesterday evening and checked it this noon and the display was still showing "charging".
Is this normal behaviour?
This is normal behaviour. "Charging" is a state information telling you that it is correctly placed in the charger rather than it is really charging. Likewise with the Beocom 6000 where the charger (or the phone itself for the newer models) indicates "charging" with a green LED, which only means that it is correctly placed in the charger. "Docked" or something similar would probably have been a more correct information rather than "charging".
Charging is controlled by the software in the same manor as with the cordless telephones.
Br,
Bjarne
