Welcome to Beoworld ! And thanks for signing up as a silver member, your support is greatly appreciated !
There are speed fine adjustments reachable from below through two small holes in the bottom plate. The trimmers inside could be bad, that's very common, but could also just need a little motion.
Normally, the speeds and the tracking force are the only things you need to adjust.
