Hi All,
I recently bought a CD5500 of ebay that was advertised as in good working order. Obviously it only has draw open and play buttons on the front. If you put a cd in the track indicator comes on for about 5 seconds then goes out. It doesn't highlight any tracks and won't play cd's.
I am assuming that it should play as a standalone. I haven't got a 7pin data lead yet but assume it would work with a 5 pin din ( without data control) but it doesn't.
Can someone confirm that it will play disc's without being connected to the beomaster via the datalink cable.
Steve
