Latest post 05-16-2007 2:29 PM by Kevin. 6 replies.
Page 1 of 1 (7 items)
  • 05-16-2007 8:41 AM
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    Aircraft engineer humour
    I know there are a few pilots on the site (not sure about aircraft engineers)
    P:    The problem reported by the pilot in the log book
    S:    The solution reported by the mechanic
    P:    Left inside wheel almost needs replacing
    S:    Left inside wheel almost replaced
    P:    Test flight OK, landing by autopilot too rough
    S:    This type of aircraft does not have autopilot landing installed
    P:    Something is loose in the cockpit
    S:    We have fixed something in the cockpit
    P:    Dead bugs on windscreen
    S:    Live bugs in backlog
    P:    The autopilot started to lose altitude at 200 fpm despite being set to "maintain altitude"
    S:    Unfortunately we were unable to reproduce this problem on the ground
    P:    Note pointing towards leak on right-hand side
    S:    Note removed
    P:    DME is unbelievably noisy
    S:    DME re-set to more believable noise level
    P:    IFF not functioning
    S:    IFF never functions when switched off
    P:    Suspect cracked windscreen
    S:    Suspect you're right
    P:    Engine No. 3 missing
    S:    Engine No.3 found under right wing after short search
    P.    Plane flies funny
    S:    Plane admonished to take things more seriously
    P:    Target radar humming
    S:    Target radar reprogrammed to speak properly
    P:    Mouse in cockpit
    S:    Installed cat
    Laughing
  • 05-16-2007 10:50 AM In reply to
    Re: Aircraft engineer humour
    P : Evidence of oil leak from right side landing gear.
    S : Evidence removed.
    P : No 2 engine leaking oil
    S : Oil seepage is normal and within limits, other 3 engines not seeping enough.
  • 05-16-2007 11:10 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Kevin! I've got tears in my eyes after reading that.
    Absolutely hilarious!
    Andy T.
    Poor me, never win owt!
  • 05-16-2007 11:13 AM In reply to
    • 9 LEE
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Brilliant !!
    LaughingLaughingLaughing
  • 05-16-2007 12:01 PM In reply to
    • Stonk
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    P: Turn & slip indicator ball stuck in center during turns.
    S: Congratulations. You just made your first coordinated turn!
    P: Whining sound heard on engine shutdown.
    S: Pilot removed from aircraft.
    P: The autopilot doesn’t.
    S: It does now.
    P: Unfamiliar noise coming from No. 2 engine.
    S: Engine run for four hours. Noise now familiar.
    If you think nobody cares, try missing a couple of payments.
  • 05-16-2007 1:42 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Thanks Kev.Laughing
    Craig Big Smile
  • 05-16-2007 2:29 PM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    @ the additional ones
    LaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughingLaughing
