Latest post 10-26-2009 5:24 AM by Orava. 2 replies.
Page 1 of 1 (3 items)
  • 10-25-2009 5:30 AM
    • Orava
    • Not Ranked
    • Joined on 10-25-2009
    • Finland
    • Posts 28
    Beogram CD 5500
    Hello everybody
    I have a 5500 CD. It indicates Radial servo problem in service mode.
    I wonder if there is any known, typical problem with it? Please let me know if any ideas.
    Filed under: , ,
  • 10-25-2009 6:39 AM In reply to
    Re: Beogram CD 5500
    Looking around, the problem can often be the electrolytic capacitors on the servo board. It affects many of the Philips based machines, not just B&O. The solution is to replace the electrolytic capacitors and check the soldering on the board generally.
  • 10-26-2009 5:24 AM In reply to
    • Orava
    • Not Ranked
    • Finland
    • Posts 28
    Re: Beogram CD 5500
    Mm, yes, I found these cap problem solutions, and have change all of them (there is not too many on this), but it did not help.
    Maybe it needs some scoping, unfortunatelly I can't do it now due broken hardware...
