        1st March February 2012
	    Latest post 08-09-2008 8:54 AM by Kim.t . 9 replies.
								    |  08-09-2008 2:27 AM |  |
									                 Kim.tJoined on 04-17-2007Posts 18 |
										    Mapping keys from BL5000 -> BEO4
										    Where can I find a overview of mapping of keys from a BL5000 to a BEO4 / BL1000. I have bought a 2.hand lintronic box, but the box does not react on keys like A.RECORD, V.RECORD, TURN....... BM7000,CD7000, MX4000, VX7000,2 BL5000, BL1000, 2 CX50, 2 Beocom 6000, Beocom 2500, Beocom 1600 |  |
									                 PeterJoined on 02-12-2007Posts 9,572 |
										    Re: Mapping keys from BL5000 -> BEO4
										    I can see that being complicated! I take it that you are using the BL5000 in two way mode. I have not seen a conversion chart but if you are using a one way TV, the first thing I would do is set the remote to one way for video signal. (I guess you have already done this). I would concentrate on getting the Beolink 1000 working first and then try the BL5000. I am sure Michael at Lintronic will be able to advise though.  |  |
										    The problem is that both TV and audio are 2-way - thats why I don't want to change to 1-way. The core problem is that I can't get the 238 box to react on the V.RECORD, A.RECORD, TURN and other BL5000 specific buttons. I have seen such a chart once in a manual but I can't remeamber where. I Guess I have to dig. BM7000,CD7000, MX4000, VX7000,2 BL5000, BL1000, 2 CX50, 2 Beocom 6000, Beocom 2500, Beocom 1600 |  |
										    Out of interest, what are you getting the Lintronic box to do?  |  |
										    Also found what you were looking for!     |  |
										    Thanks, from which manuel did you get the picture ? My goal is to operate my Sony HX750 HDD recorder and my TViX M-4000 media player with my BL5000. On the Sony the Subtitle key should be mapped to the TURN key, The HDD and DVD button to the V.RECORD and A.RECORD. Another key that the box don't react on the the REC.STOP key - the REC.START key is OK. BM7000,CD7000, MX4000, VX7000,2 BL5000, BL1000, 2 CX50, 2 Beocom 6000, Beocom 2500, Beocom 1600 |  |
										    I use a DVD controller for my Panasonic HDD/DVD-R/Freeview box - quite successful!  The page is from the Beocenter 9500 user manual - I remembered seeing it many years ago so had a little search!
										    I also found an owerview in the "Video system 7000" manual where other key combination are listed. Maybe I shold upload a picture to this thread once I find my scanner. My MX4000 is 2-way - but was sold with a BL1000 BM7000,CD7000, MX4000, VX7000,2 BL5000, BL1000, 2 CX50, 2 Beocom 6000, Beocom 2500, Beocom 1600 |  |
			     Page 1 of 1 (10 items)  |
