1. It looks stunning anywhere, as most B&O products do.
2. You have FIVE good, balanced speakers inside.
3.You can change the front grill cover to suit your mood, colour, or design palette.
4. It plays CD, and programmed or random FM radio, with or without the Beo 4 remote.
5. You can turn the volume down, and back up again when using a B&O telephone.
6. It is portable, with a hidden antennae one can raise or not..
7. Using the AUX plug underneath the BS 1, you can use in an IPOD, or MP3 player .
8. Using the same AUX plug, you can use it for a Home Stereo System, using DVD, TV, or SAT TV components.
9. The newer units have an alarm and will play downloaded CD copies.
10. The function LCD displays time, CD track, and radio program selection.
That's my admittedly biased, top ten features.
A great little design !
