I inherited a Beomaster 2000 type 2913 from a relative. I discovered that one of the speaker channels sounds muted at maybe half the volume of the other channel. After switching right and left speakers, replacing speaker jacks and wires, I believe one of the speaker outputs is bad. Is this something that is worth fixing? Will it be costly? Can it be done at home?
