Latest post 07-29-2008 3:29 PM by Coolskin. 3 replies.
Page 1 of 1 (4 items)
  • 07-22-2008 8:37 AM
    BM-Link 1.5 and BeoPort
    I have a problem with my BeoPort. I'm using iTunes 7.7 (43) and OSX 10.4.11 and BM-Link 1.5 and firmware 1.31.
    The problem is that BM-Link shuts down after a minute or so. The remote doesn't function either. I've tried to install the older version after uninstalling the new one, without any luck.
    Any ideas?
    Filed under: ,
  • 07-22-2008 4:17 PM In reply to
    Re: BM-Link 1.5 and BeoPort
    Same happend to me with the 1.5 version.
    I removed the 1.5 version and installed the older version.
    Now it's up and running and keeps on going.
    setup: PowerBook G4, Mac Mini (stone age, no IR sensor), BV7-32 (stone age), SW 10.4.11
  • 07-29-2008 11:08 AM In reply to
    THANX!
    I've tried to do the same, but I can't download, the old version...
     - I'll try and contact Anders Odlund, to see if he can send the file to me.
  • 07-29-2008 3:29 PM In reply to
    I tried it, and had succes.
    Maybe you have your computer in private mode ?
    If so all downloaded files disappear from the download center.
    Oh, and the files are only for MAC.
