I have a concern that this senario may cause problems and I would like to buy a beoport.
Main room: BV7MKII, BS9000MKII with BG4500 connected to the aux port. Lots connected to the BV7 as well...
Various equipemnt in link rooms.
If I connect a beoport in the same room will I still be able to select the Turntable and play records? The Beo4 commands PHONO, N.MUSIC, A.AUX are the same from memory. So how would I select either digital music from the beoport or vinyl as they are seperate sources? If it does work would I have problems in the link rooms? I do need an N.MUSIC upgrade for the BS9000 in any case.
Hope I explained that well...
Thanks, Beoaus.
