Is there a link that I have missed to enable corrections to be made / sent to someone to correct the listing of product specifications?
I am about to move my RL140s (bought new when first released in 1986
) and wanted to find the weight and size.  I decided it would be easier to have a quick look on the web site as I was at my PC.  However the size seemed all wrong and the frequency response plus crossover details did not match up with my recollection.  I think the specifications against RL140s are for RL 45s!
The size should be 70 x 50 x 24, weight 15kg and respone 40-20,000 +4 - 8db
 Whilst on the subject of help  - I have photographs of the brackets used to fix these to the walls but do not know how to send them so another member can see them.  Please help.....
