Very good quality and reliability. Depending on the age of the panel it MAY be able to upgrade to HD, via a software update in the Beosystem 2 and a firmware upgrade and blade in the Beovision 4. I'd check with a dealer to see if the serial number denotes it as a D6 or D7 panel - if it is D& then you are laughing.
Either way, if you are only looking at SD material, then it is a fine unit.
