I have a problem with BeoSystem 1. Every time when I turn it on sound level is extremely low, looks like only BeoLab 2 is on.
When I go to Menu-->Sound-->Speaker Level then change it from Auto to Manual or the other way around it resets and works fine until I shut it down. Need to go through this every time I turn it on.
I use it with Lab 8000 Lab 2 (no center speaker yet)
Any ideas or suggestions?!
Thank you
