1st March February 2012
05-07-2008 1:36 PM
11048437
![](/utility/anonymous.gif)
![Top 200 Contributor Top 200 Contributor](/Themes/beotheme1/images/rankicons/rankTop200.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 04-17-2007
- Posts 352
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
schematics RCA to Powerlink
hi, I would like to connect a Beosound 2 player directly to Beolab 3 speakers. Has anyone of you a schematics of this cable transformation? Thanks in advance, Constantin
Bulgarien
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.24.58/avatar.jpg)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
- Denmark, Vest Sjaeland
- Posts 201
Re: schematics RCA to Powerlink
Try these two link , all kind off schematics should be there... Peter Pans B&O adapter : ____________________________________________________________ Vil du kun se DIN stik, kabler / forbindelser, så se tegninger du kan lodde efter her. B&O DIN Adapter Cabel Connection. = Kun DIN forum:.
You can use both 5 and 7 pin DIN plug, its make no difference, in this set-up ![](http://img384.imageshack.us/img384/1084/20061001103656adaptertiei9.jpg)
Puncher
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.46/avatar.jpg)
![Top 10 Contributor Top 10 Contributor](/Themes/beotheme1/images/rankicons/rankTop10.gif)
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Does the BS2 have a phono connector?? Surely its a 3.5mm stereo jack?? Or do you mean a Beocentre 2??
11048437
- Posts 352
Bulgarien: Try these two link , all kind off schematics should be there... Peter Pans B&O adapter : ____________________________________________________________ Vil du kun se DIN stik, kabler / forbindelser, så se tegninger du kan lodde efter her. B&O DIN Adapter Cabel Connection. = Kun DIN forum:.
Thanks very much!! Do you think that Beolab 3 will Power On the moment I'll send signal on R and L channel? Constantine
11048437
- Posts 352
11048437: Bulgarien: Try these two link , all kind off schematics should be there... Peter Pans B&O adapter : ____________________________________________________________ Vil du kun se DIN stik, kabler / forbindelser, så se tegninger du kan lodde efter her. B&O DIN Adapter Cabel Connection. = Kun DIN forum:.
hm.........there are so many schematics there... I thinlk I'll need a voltage signal on the Trigger ........
11048437
- Posts 352
11048437
- Posts 352
11048437
- Posts 352
Puncher: Does the BS2 have a phono connector?? Surely its a 3.5mm stereo jack?? Or do you mean a Beocentre 2??
Hi Puncher, It's not about a beocenter 2, it's about a Beosound 2.... The ideea is that I bought a pair of Beolab 3 speakers on E-Bay from USA and the guy does not wanted to send them in Canada. I have found a solution: the guy will send the speakers in Plattsburgh, New York via UPS with the Hold For Pick Up option, and then I'll go there(88 km drive) to collect them. I would like to try them on place so that's why I'll need a way to verify them on place( in case I'll enter in Canada with them, then I have to pay 300$ Custom fees and if they «are not working, I'll have to send them back - difficult to have my 300$ back as I have to fill a lot of papers............It is a mess I know but the price of the BL3 was so good ..... Constantine
Hagen2000
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.32.34/avatar.jpg)
- Joined on 05-08-2007
- Munich
- Posts 267
I would try the Beolab 3 speakers using their line input. In this case you won´t need a trigger signal to make the speakers work and you will only need a simple 3.5mm stereo jack to cinch adapter!
The Stig - ver. 1.7
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.40.19/avatar.jpg)
![Top 75 Contributor Top 75 Contributor](/Themes/beotheme1/images/rankicons/rankTop75.gif)
- Joined on 06-20-2007
- Posts 898
It's not the schematic to use.... You will need a mini jack and two "7" pin Din. Connect ground to pin 2 and 7, for the left speaker you connect the left sound signal to pin 3 and 5. and the same for right signal in the other plug. and then set the speaker to "line" and it will work.
Page 1 of 1 (10 items)
