Latest post 05-22-2008 1:36 PM by drevil2k2. 1 replies.
Page 1 of 1 (2 items)
  • 05-21-2008 11:02 PM
    Connect computer to B&O
    I own a Bang and Olufsen Beosound 2300.
    I want to hook my computer up to the system so I can use it to play my iTunes.
    That is the best (i.e. cost effective) way to accomplish this? The computer will be in a separate room from the Beosound. Can I hook them up via some sort of cable that will connect directly into my computer. Or will I need to purchase a receiver. I would like to avoid the receiver optoin as they seem to be $500+ for good quality.
    Thanks!
  • 05-22-2008 1:36 PM In reply to
    Re: Connect computer to B&O
    From my limited reading, you can use an ipod cable, connect from your computer's sound card line out, and then to the AUX of the BS2300.
    I am not sure about the sound quality with this method. I have read also that buying a DAC can improve the sound quality and volume.
    Since I am new to the forum, I am sure other members can shed some more light.
    Cheers
