Hi:
I am attempting to isolate a problem on one of these machines. Basicly I think there is an issue with the power supply as there is not enough power getting to the machine for the display to light-up or for the tape mechanism to work. When I have it open I notice a repetitive squeaking noise coming from the power supply (I think). Sometimes however, when you turn it on for a fleeting second it makes the noise you would expect it to make if it was going to accept a tape but then goes back to squeaking.
I know these things are ten-a-penny these days. However, if there is an easy fix or it is glaringly obvious what this is I would like to get it done.
Graham
