Latest post 04-17-2008 5:55 PM by kevinoils. 8 replies.
Page 1 of 1 (9 items)
  • 02-06-2008 12:44 PM
    • prime
    • Not Ranked
    • Joined on 02-06-2008
    • Posts 2
    MMC cartridges - I need a backup
    Hi my name is Rich and this is my first time posting in this forum and any help would be appreciated.  I have a Bang & Olufsen Beogram RX 2 turntable.  I would like to get a mmc cartridge as a backup.  Is there any chance I can get one under $100.  I seen some prices online and they seem a bit high.  Thanks again for you help!
  • 02-06-2008 2:06 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: MMC cartridges - I need a backup
    Hi Rich & welcome to BeoworldSmile
    Is it fair to assume that the cartridges you have seen on line are from www.sound-smith.com ?
    If so then they really are your best bet by a long shot. Their SMMC4 is far superior to the orignal B&O MMC4, I know as I own one as do other Beoworld members! Not as refined cosmetically but worth every penny though. I wouldn't bother with a 2nd hand B&O item as the suspension is likely to have hardened by now and you have no guarantees over its longevity, unlike the soundsmith ones which have a full warranty.
    Chris.
  • 02-07-2008 5:41 PM In reply to
    • prime
    • Not Ranked
    • Posts 2
    thanks...seems like my best bet.  Just checking :)
  • 04-17-2008 2:34 PM In reply to
    Where are you? If you want it, I could sell you a good TX turntable and MMC2 cart for $200 but you'd need to pick it up in northern NJ, USA. phil
  • 04-17-2008 3:09 PM In reply to
    Hi Chris
    Do you know of anyone that has sent their MMC range for re-tiping or a new cantilever etc from Soundsmith? I am considering sending a broken MMC 4 to them. I assume that they deal with the suspension etc when it is taken apart by their engineer Peter. I just done know how they get into these as I cant see any way of taking them apart, any knowledge on this stuff.
    Ps very temted to get a Soundsmith stylus, though not their new top of the range model lol
    Kev
  • 04-17-2008 4:08 PM In reply to
    • Medogsfat
    • Posts 4,045
    Hi Kevin,
                 no I don't and to be honest it would probably be just as expensive to have done (if not more so) than buying new.
    Chris.
    PS. Have you checked the wanted section?
  • 04-17-2008 4:30 PM In reply to
    Hi Chris
    I checked with Soundsmith website and they do replace the cantilever on original cartriges for less cost than buying their own model, a replacement ruby cantilever and nude contact line diamond on an MMC 4 same as smmc 2($529.95) would cost $250. I have sent them an e-mail to query this.
    I am really tempted as is my new B&O converted buddy to get one, either a new smmc4 as I trust what you say that they are good.
    Oh checked wanted section you have replied to my post ,,,hey cheers Chris. I would be interested in the 2200 platter and hopefully will maybe get a closer match to the original also soon, the one ive got is badly marked, scratched. How much you need to get it on its way?
    Cheers
     Kev
  • 04-17-2008 4:35 PM In reply to
    very interesting pricing there...
    i wonder if they do "other" rebuilds besides just the needle, re: i have a mmc 3 w/ the right channel out, otherwise fine.
    thx for the info...
    • B&o bottle opener
  • 04-17-2008 5:55 PM In reply to
    Hi Jeff
    I am waiting on a reply from Soundsmith nothing as yet, but its just how far can they go in the re-build, one of your channels is out, I wonder what they could/would do for that? I think also the pricing is good if they can re-use the MMC4 cartriges, Chris mentioned the suspension going due to age I am curious to know what they can do in these situations if the repair that?
    Cheers
    Kev
