Hello All.
I am unable to get by BS4 and BL3500 to communicate via the Wireless 1's I own.
I have:
BL3500 (V 2.0 - dealer said that would be ok)
BS4
Wireless 1 (FW 2.03a) - Connected to each by ML cable ONLY (no PL, IR, etc)
On a direct ML-ML connection, my BS4 and BL3500 comunicate perfectly.
When connected via Wireless 1, I can get the clock to sync (for example) and the "all off" command (holding down the red dot on my Beo4 for 3 secs) to work (so I know there is SOME communication between the two units), however it seems that I cannot bring the Wireless 1's out of standby as when I press Radio, CD, or A. Mem on my Beo4 in the remote room, my BL3500 clicks on and after 3 or 4 seconds clicks off. Neither Wireless 1 unit light goes green.
The rooms are basically a wall away and there is zero interference in this building.
Can someone please help? I can't drill holes here for a number of reasons (which include renting as this is a corporate apt.)
Thanks!
