Latest post 04-03-2008 4:01 PM by timmer66. 4 replies.
Page 1 of 1 (5 items)
  • 04-01-2008 11:27 PM
    • timmer66
    • Not Ranked
    • Joined on 03-03-2008
    • Polson, MT
    • Posts 36
    BeoCenter 9000 / BeoGram 5005 / BeoLink 1000
    Can I operate a BeoGram 5005 through my BeoCenter 9000 with the BeoLink 1000?
    I'm looking for a compatible turntable with remote capability through the BL1000.
    Any suggestions?
    Thanks,
    Tim
  • 04-02-2008 10:32 AM In reply to
    Re: BeoCenter 9000 / BeoGram 5005 / BeoLink 1000
    This combination will work fine. The 5005 is only a Beogram 9000 with cosmetic changes like the number and the colour of the bed.
    Regards Graham
  • 04-02-2008 10:59 AM In reply to
    • timmer66
    • Not Ranked
    • Polson, MT
    • Posts 36
    Thanks - that's what I was hoping for.   Will the Beogram 5000 work as well?
  • 04-03-2008 3:40 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    timmer66:
    Yes it will.
    Other models which will work and give you remote control include:-
    Beogram 3000 (tangential model) 3300, 5500, 1800, 2000 , 9000 (obviously) 8500 & 9500 (1980's models) - non of these have the inbuilt RIAA which is already fitted in the Beocenter 9000.
    Chris.
  • 04-03-2008 4:01 PM In reply to
    • timmer66
    • Not Ranked
    • Polson, MT
    • Posts 36
    Thanks!  That's great - those are the ones I've been looking out for.  I just (today) bought a BG5000 with an MMC2 - I'm hoping the cartridge is in decent shape as I just spend a chunk of change on a cartridge for my BG4002.
    Tim
