Hi, I just discovered these great BeoWorld forums while searching for a solution to a problem my BeoSound 3000 developed yesterday. B&O service says it will be a 3-week turn-around for repair, so I'm hoping there may be some simple fix.
The problem is that, when I load a CD and then press the CD button, the clamp comes down and it starts spinning -- all normal so far -- but then after a few seconds it stops spinning. The display says LOAD CD. The message is wrong, of course, because the CD is loaded.
Sometimes it does work. The CD keeps spinning and plays through to the end. But usually not. On one occasion, it played for about a minute and then stopped.
This unit has functioned perfectly since I purchased it 30 months ago. Ideas, anyone?
Thanks,
Peter
