thorne:Some overcurious fingers have been playing with my Beotalk and also the power has been disconnected several times for short periods of time. The result is that when it is powered up it defaults to silent answer, and rate saver and listening in modes are all activated, and the ringing time defaults to 55 and not 15. The time has to be reset each time power is disconnected and all entries in my voice announcement phonebook have been wiped out. In addition, incoming calls ring once, then stop and no message is relayed to the caller. Any thoughts?
Hi Thorne or anyone else who has a resolution,
did you ever resolve this problem?? It appears that I have exactly the same problem. I was disconneting beotalk 1200 a number of times in a short period, while moving the machine to a different location, and since then it has started powering up in a different mode, sort of. Most annoyingly it doesn't show the caller id anymore, it just blinks when an incoming call is received. The ringing time is default to 55 s, while it should be pre-set to 15 seconds according to the manual. The machine was working perfectly before and I use exactly the same cables. Does anyone know what has happene`?? Thank you very much.
