I think the problem will possibly be that you need to reset the BL7000. You need to remove all components, then store: then add your components. The Beolink 7000 sets itself as two way by sending a signal and waiting for a response. If it gets none, it sets the component to one way. Do you know how to do this? If not, we can walk you through it.
