Latest post 03-08-2008 2:23 PM by Craig. 3 replies.
Page 1 of 1 (4 items)
  • 03-08-2008 1:20 PM
    Beomaster 2200
    Hi, I have one of these along with a beogram 1902 and some S45.2 speakers, and it makes a lovely sound. however, having no user guides with it, and never having seen one before, I was just wondering what the P1, P2, P3, P4 and P5 buttons do. I assume they link to the  5 dials which raise out above them ,but what do they control, and how are they used? As if i press one of the buttons, it raises the phono buttons and kills the sound.
    CT
  • 03-08-2008 1:28 PM In reply to
    Re: Beomaster 2200
    They are the preset radio channels. When you press the dials , they come up and there is a geared wheel that when turned allows you to change the frequencies. These are actually the best pre-set design from this era as being geared they allow very fine tuning. To select the programme, press the button on the front panel.
  • 03-08-2008 2:00 PM In reply to
    Re: Beomaster 2200
    Oh I seeee. Nice touch there. now I just need an aerial Smile
  • 03-08-2008 2:23 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beomaster 2200
    Is the cover for the connections in place? If not I have one knocking around somewhere.
    CraigSmile
