Is it difficult to install this yourself?
Is it the same 4015 as used for the BC6?
are there modules secondhand?
Not difficult to install but expensive ~£150!!!! Not sure whether other modules will work but you could check the part numbers with your dealer or the service manuals on this site.
I would imagine they are as rare as hens teeth secondhand.
Regards Graham
