Hello . Having a problem with Sky+ commands on ITV2 & ITV3 . When either is pressed it seams to miss the middle ' 1 ' in the command , the small Sky+  number box that appears ( same one if you key in numbers on the Beo4 ) shows ' 18- ' but should be 118 and the same for 119 ( 19- ) , it hangs waiting for the last of  three numbers  . All other Sky channels work fine and have looked in the Configuration edit and view and it outputs the correct CIFFER numbers when tested in there .
The shop first set this up for me but I have been altering a few things but not any of the Sky+ , I've been adding a few Logo's to the home screen , I have cameras in some aviaries and now have a cockatoo Logo to select it and an old Beolit to call radio , working on a BeoVision 3400 to call Tv.
Richard
