The microswitch itself could be at fault. I think it's safe to test tripping it manually, it becomes visible when the sled is around halfway through its travel. The arm should raise and the unit shut down.
Anyway, the power supply is controlled electronically, and not directly by the switch. You might have a bad solder / diode / transistor somewhere along the path, or even a suitable short circuit.
-mika
