Roger,
Welcome to Beoworld !
Nice system you got there !
1 Speaker wires - there are 4 ports which should the speakers plug into?
You decide, there are connectors for two pairs. You would want to connect to f.e. speakers 1 (left and right).
2 Is there a master mute for everything ?
There are two speaker switches which is probably the reason for the missing sound, They are the ones nearest to the power key and handles each their pair of speakers. If you connected the speakers as set 1, the speakers 1 key must be down to allow sound to the speakers.
3 The receiver has a light on so think it is working. There is no static or anything whilst tuning. The stereo light came on in one position which makes me think it is picking something up that i can't hear. I fitted an aerial wire from another stereo into the aerial port and still nothing.
Probably because of the speaker switches or you have the volume control all the way down.
4 So I tried the record deck.  I cannot find a master on / off! I expected the turntable to turn but it does not. Do you need to set the record on the amp before it knows it's on? Does it matter which line in the deck is plugged into? I know some amps have a more sensitive setting for record.
If this is a Beogram 1000, it will start rotating the platter when you lift the tonearm out of its holder and place it over the lead-in groove of the record. The tonearm will raise/lower using the control at the front of the tonearm holder. There are two phono inputs on the Beomaster 1000. Which one to use depends on whether your Beogram has a built-in preamplifier or not. Go easy with the volume control and use trial and error to determine
We like photos very much. When posting, click the "options" tab and then click "Add/Update" to browse and upload a photo file of max 100Kb.
Hope this helps !
