Our Beomaster 2000 suffered a lightning stike a while back. The unit powers up and all of the touch panel functions work properly, as well as the power amplifier. But... it suffers from a lot of noise on the speaker outputs.
My guess is that the lightning strike may have blown some capacitors which filter noise from the tuner stage to the power circuits, causing that noise to leak (through the power circuitry) over to all of the other circuits.
Have not tried the headphone or tape recording outputs yet. Noise is present on all of the inputs (including phono and tape). Volume, mute and power controls work without any problems, though. The noise sounds like a badly tuned radio (some broadcasts can be heard).
Is my unit dead or can it be repaired, for example by resoldering new capacitors? I don't have the schematics for the 2000, can a B&O dealer help me with those?
