Thanks in advance to all of you who have posted suggestions to my prior posts seeking advice for my home theater set-up.
Two remaining decisions: DVD player and rears.
Kit will be BV 4-50 TV, BS3, BL7-2 center, BL6000's fronts.
Question on rears: Can a pair of BL4's do the job or should I get a pair of BL4000's? Rears will be ceiling mounted, about 11.5 feet high (3.5 meters) and about 6-9 feet (1.8-2.7meters) behind the main viewing seats.
Suggestions for DVD player: What players are any of you using with a BeoSystem 3? I've been considering a Samsung BD-P1200 blu-ray, which I am told works perfectly with the system and Beo4 remote. Is a blu-ray dvd player overkill for the 720p TV? Would I be better off with just an upscaling DVD player? I would prefer a player that integrates with the Beo4 remote-- which is why I'm not considering the PlayStation 3.
Thanks-- as always-- for your input.
Todd
