Latest post 01-19-2008 12:29 PM by 355f. 8 replies.
Page 1 of 1 (9 items)
  • 01-18-2008 9:15 AM
    BV4 50" table support
    Hello everybody,
    My dealer told me about this table support option for the 50" plasma screen some time ago, but I've never seen it;
    could you help me to find a picture or a link please?
    thanks in advance.
    Santiago
  • 01-18-2008 3:05 PM In reply to
    Re: BV4 50" table support
    Santiago,
    I do not have an actual real picture, but I do have a diagram in a PDF document which you can download from HERE
    Regards Keith....
  • 01-18-2008 3:43 PM In reply to
    Thank you very much Keith!
    With your document I have an idea now about his shape and size Yes -  thumbs up
    Best regards.
    Santiago
  • 01-19-2008 8:24 AM In reply to
    Santiago,
    Below is an actual picture supplied to me by Gordon at B&O Salisbury, my thanks to him for the picture.
    Table Stand
    Regards Keith....
  • 01-19-2008 9:56 AM In reply to
    Thanks a lot to both, Gordon and Keith ! Yes -  thumbs up
    I'm seriously thinking to buy a BV4 instead a BV7, changing my mind to plasma from LCD, but I've not a wall behind to hang the beast Yes -  thumbs up
    Definately the table stand is very nice Smile
    Best regards.
    Santiago
  • 01-19-2008 10:08 AM In reply to
    The table stand is very similar to Pioneer's table stand.
    Borja
  • 01-19-2008 10:45 AM In reply to
    • 355f
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Posts 655
    Santiago:
    Best regards.
    Actually the table stand is  a large heavy alloy stand that has quite some depth at the rear or the screen
    You could look at a Pioneer floor stand- looks very BnO all in alloy- if you wanted to floor rather than table mount
  • 01-19-2008 11:30 AM In reply to
    355f:
    Hi 355f,
    BV4 would be over a table for sure (not on floor stand), probably something like this or this... so the table stand depth and size is not a problem at all... but now I'm thinking how to place the BL7.2... and that's more difficult !! I can see that BV4 stay too low, so surely I'll need to put something under the stand to lift it over 10cms and let space enough for the BL7.2 Hmm
    Santiago
  • 01-19-2008 12:29 PM In reply to
    • 355f
    • Posts 655
    Santiago:
    355f:
    Hi 355f,
    Thats not going to work to well!  I have mine on a table stand. problem is that the base of the stand protrudes 3 in in front of the screen and about 8 behind so actually its impossible to mount the speaker in the way you suggest. the speaker protrusion is to great
    My solution was to place the BV4 on the table stand on a coffee table with wide marble supports either side and then mount the BL7 under the table- Actually it works ok.
    But when the BL10 comes out I will buy the pioneer floor stand and mount the bl10 under the screen as its the same depth
