Latest post 04-30-2007 7:58 AM by GSHaigh. 2 replies.
Page 1 of 1 (3 items)
  • 04-30-2007 3:59 AM
    DVI and HDMI
    My BeoVision 7 32" has a DVI input for HD TV. What ist the difference between DVI and HDMI input? Would I need an adaptor to watch HDTV or is DVI also good for watching HDTV?
  • 04-30-2007 4:45 AM In reply to
    • jchasey
    • Not Ranked
    • Joined on 04-17-2007
    • Hampshire, UK
    • Posts 11
    Re: DVI and HDMI
    Main difference is that HDMI includes sound cables, but DVI does not. Also HDMI supports copy protection.
    You can buy a convertor to go from one to another, on a purely video level, the signals are the same.
    No problems with watching HDTV, other than you will need seperate cables for the audio.
  • 04-30-2007 7:58 AM In reply to
    • GSHaigh
    • Top 500 Contributor
    • Joined on 04-16-2007
    • North West UK
    • Posts 163
    Re: DVI and HDMI
    DVI also supports the copy protection (HDCP).
