Latest post 01-17-2008 6:12 AM by Santiago. 3 replies.
Page 1 of 1 (4 items)
  • 01-16-2008 7:58 PM
    BeoLab 1 Column Dimensions
    I'm wondering if someone knows (or could measure) the dimensions of the column of the BL 1 speaker. I can only find the height and the diameter of the base. The column appears to be (sort of) ellipictical in cross section. This is the measurement I need.
    Cheers
    Stuart
  • 01-16-2008 11:28 PM In reply to
    Re: BeoLab 1 Column Dimensions
    Hi Stuart,
    I just measured mine: 17.2mm from side to side and 14.5mm from front to back.  Let me know if you need any other dimensions.
     s.
  • 01-17-2008 2:34 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    turbotol:
    Hi Stuart,
     s.
    I guess you mean cm!
  • 01-17-2008 6:12 AM In reply to
    Exactly,
    17,2 and 14,5 are in centimeters, and the both straight (flat) sides of the cross section are 8 cms each.
    Regards.
    Santiago
