I have a question regarding the sound of a beomaster 8000. I recently bought one and intend to replace the capacitors in due course but have noticed a couple of thngs about the unit I have.
The sound, whilst very dynamic, sounds just a little 'lacklustre' The beocenter 7007 that I also have has a much richer sound (with same source & speakers) Im using an ipod plugged into TP2 on both.
I'm womdering if Im hearing the symptoms of tired capacitors? Also if I try to engage the filters both channels dim considerably but the right cuts out almost entirely and objects strongly to the tone controls being moved! much crackling ensues ;-) Im not to bothered in terms of functionality, I don't use tone controls, but would like it all to work as it should!
Any ideas appreciated, although I realise I must do the capacitors :)
thanks,
Adam
