Latest post 01-13-2008 4:26 AM by Peter. 7 replies.
Page 1 of 1 (8 items)
  • 01-05-2008 6:42 PM
    Latest play! I bought my daughter a microscope for Christmas! I need an attachment for the stereoscopic one but this is from the compound microscope.
  • 01-06-2008 5:48 AM In reply to
    Re: MMC20CL
    Brilliant Picture!
    Simon
  • 01-06-2008 12:23 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: MMC20CL
    What magnification is that picture taken at, looks very good anyway.
    CraigSmile
  • 01-09-2008 6:05 PM In reply to
    Re: MMC20CL
    Another go at higher magnification!
  • 01-09-2008 6:09 PM In reply to
    Re: MMC20CL
    Interesting aside! The B&O cartridges are set so that the diamond, which is square, is set so that the diamond tracks with the parallel surfaces parallel to the grooves. The Soundsmith cartridge is set at 45 degrees to this so that the edges are next to the grooves. Not a lot of people know this.....Laughing
    Obviously the part of the diamond that tracks the groove is the cut part which is heavily sculptured on both.
  • 01-12-2008 5:22 PM In reply to
    Re: MMC20CL
    Think I am getting better at this!! CL again!
  • 01-12-2008 10:59 PM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    Re: MMC20CL
    Amazing images! Does the Soundsmith or the original orientation result in better sound?
  • 01-13-2008 4:26 AM In reply to
    Re: MMC20CL
    Of the cartridges I have, the SMMC20EN would seem to be as good as any of them. It is probably 15 if not 20 years younger though! Now I have cleaned the 20CL properly, I'll have another listen! I can't see that it shoule make much difference - unless someone knows better!
