Hello
I need to fix the foam for a Beovox C75 speakers. Just a
question, the upper drive has a foam suspension and the lower a rubber
suspension; is this right? The two driver (in the same speaker) are
different and I don't know if this is correct or not, the code for the woofers are:
8480143 (B&O)
8480141 (?)
The dome tweeter code is
H216 51/80-3
I need to change the foam but 2 are in foam and the others are in rubber.
Where I can find the exact replacements?
Thanks a lot from Italy
