Am I right in thinking that the bass and treble should have red lights on the display? I have just been given a 1900 and if so these bulbs need replacing. Is it an easy job and where do I get them from/ how much?
Cheers
Hi Jacob
Contact Dillen, technical adviser on Beoworld. He sells the lamp kits for the BM 1900. As he will surely suggest, you might as well replace all of the lamps whilst you have the unit open. Trust me its a lot of work taking it apart and putting it back together again but worth it a 100%!!
Good Luck!!
Durban South Africa
Yes, the lamps need to be of correct wattage and actually need to be all working to guarantee correct operation.
A kit is available for convenience, it comes with (dis-)assembly instructions. Basic electronic tools are needed.
