Latest post 12-15-2007 6:06 AM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 12-15-2007 6:00 AM
    Problem with Beolab 8000
    My Beolab speakers seem to work fine with B&O stereo through powerlink connections. I understood that these speakers can be connected to non-B&O stereos, so  I connected the speaker's phono input to my Yamaha Amp and only one speaker works. I have moved the switch in the back of speakers to every position but no luck. Has anyone experienced similar problem and found an answer?
    Would appreciate your advice!
  • 12-15-2007 6:06 AM In reply to
    Re: Problem with Beolab 8000
    Have you swapped the cables over and also checked the outputs from the amp?
    Regards Graham
