Hi
Happy New Year to you.
I have had problem occur when I fitted my BT Vision to my MX TV about three weeks ago. Strangely my Beolink doesn't operate my DVD1 player any longer. And annoying I have to get up and press play to watch a movie!.
I wonder if I have changed the settings inside teh DVD player as I tried to configure the BT vision remote to work with teh TV ( I should have known better as it doesn't ) Is there a reset sequence to put the DVD player back to orginal status? Or have a done worse?
Anyway if anyone can shed some light and get me out of this mess I would be grateful
The TV works fine and the beolink works as well with the TV, the DVD plays and stops but just won't or refuse to see the remote control. I have tried two remotes!
Help
Chris
