Latest post 12-01-2007 4:59 PM by TheTinman. 2 replies.
Page 1 of 1 (3 items)
  • 12-01-2007 2:11 PM
    • beomom
    • Not Ranked
    • Joined on 04-18-2007
    • Posts 5
    BeoGram 3300 CD only goes to 9....
    Hi All,
    Our Beogram 3300 CD player will only play 9 songs on a CD - you can't forward it past 9 to get to the 10th track (or 11th, etc) - it goes back to the first track. We found this last summer and it's worked great since then - but this has started to happen recently.
    Any ideas? My husband is thinking it's some sort of setting since it only just started to happen. We have the entire 3300 system.
    Thanks!
    Kara
  • 12-01-2007 4:36 PM In reply to
    Re: BeoGram 3300 CD only goes to 9....
    Probably the motor - The CD spins faster as the laser tracks inwards - constant velocity of the medium rather than the platter and the motor will be limiting the speed - at a guess. Needs a service!
  • 12-01-2007 4:59 PM In reply to
    Needs a good cleaning, and I have found that the motor could use clean and lube on the older CDM mechs.  Nothing major, but a tech needs to do it.
