Hi Martin
Thanks for the belt kit for this turntable, they fit perfectly!
With regards to the capacitors, yes, I checked and double checked the polarity and values before soldering them into place.
The problem I had before changing the capacitors was the arm not dropping, moving to the end, and back to rest.
I'll check the solders and leads again, but i'm pretty sure they are ok.
Where can I obtain a new lamp and sensor?
Thanks,
Ben
