I would like to have the TOPFIELD 5710PVRtHDMI as STB-source.
Anyone knows if its possible to add this one in the STB-list?
I have tried TF4000, TF5000PVR and TF5800PVR but none of them worked.
It´s a BV6-26 with STB-table 3.9
BV10
Anyone?
Is it really different IR-codes from a TF5800 and a TF5000?
Is there anyway I can try another brand and see if it works? Tips?
Regards
Hebo
Hebo,
Whilst I have not tried a Topfield 5710 PVR, like most manufacturers they rarely change existing IR codes from previous models. They may add new codes not previously used however.
B&O have produced STB generated codes for the following Topfield models
Regards Keith....
Thanks Keith,
I tried TF4000 T/COT, TF5000PVR and TF5800PVR with no luck!
I have to see if there is any model supported for sale in Sweden....
Anyone with experience of Topfield-box with STB-controlling
