A while ago I had to replace the chassis of my mkI BV5
due to a faulty ML contact. After this I have noticed that the picture seems
much darker than before. Since the chassis replacement meant that the software
was changed as well I suppose that this may have caused my problem.
I have set brightness to 50 (out of 60) but it is
still hard to differ one black shade from another. All black colours just seems…black.
And if I go any higher black tends to become grey.
I suspect that some of the settings in the service
menu must have changed but I do not know how to access the service menu (if advisable
at all) or which the factory settings should be.
Anyone who can advise how to solve this problem?
Regards,
Emil
